I accidentally hit the emergency stop button on Donner. Is it OK for me to start it back up and if so, how do I do that?
If you look at the button you pushed it should have arrows on it. Rotate it about a 1/4 turn in that direction and it should pop out and turn on.
You should be fine turning it back on. You will probably need to manually turn dinner back on after you reset the e-stop. Make sure that the chiller comes on too.
Thanks for the quick reply! How can I make sure the chiller is on? This is the first time I’ve had to do this.
