Already replaced the U310 once, just in case I cooked or zapped it in my experimentation. I have a J310 that I could also try.
Bias current is set for ~15mA, closer to 12mA once the part heats up since my “current source” is a resistor.
I’d gladly test another unit if someone cared to build one and show me what I did wrong.
I’m going to set this one aside and build a different design using a common-drain design. This has the disadvantage of being slightly more noisy (higher NF).
