I need to replace both of the upper rear control arm bushings on an e36. I have an RTAB bushing removal kit (using the classic screw-a-tool method), but it does not have a tool in there of adequate OD to serve as the “screw” or “press” side of the operation. Stupid steel outer collar. I haven’t found a socket or piece of scrap in my pile at home that is the correct size – has anyone else at DMS done this particular job and know if we have a socket or something in the collection that’s the correct size? My rough measurements indicate that it needs to be about 38mm ID and not less than 40mm for the inner lip on the “press” side of the tool. The other side can just be a 27mm socket…
I’ll probably just wander over there tomorrow to see, just wondering if anybody knows anything.
I guess worst case I can just lathe down some tube that I have to make the tool. Cheers.
