Machine is on, but laser moving slowly and won’t frame or start job.
Used it earlier today and it ran perfectly. Was the laser moving slowly during cutting? Or just to move around… (Separate issue). Frame will not work if the cutting area is outside the bed parameters… (Cut area too big, or if it would run off the physical table, the cut area extending out of the bed area).
There seems to be an issues with tracking along the Y axis. It moves along the X axis just fine. When I tried starting my job, it wouldn’t move vertically, only horizontally.
Turned laser off and on again. Issue resolved.
Microsoft approved troubleshooting process. :–)
