I built a new PC this year, but hadn’t yet purchased a new graphics card. I just learned my nVidia 9600 GSO is not compatible by default with modern mining software.
Since my new box deserves a new card, I was thinking about justifying the expense of a new card by mining coins. Can anyone constructively comment on card recommendations? It’s looking like a GTX 1070 or Radeon RX580 are the current favorites.
Not looking to get rich, just pay for the card, and eventually own a couple shares of coin (less incremental electrical costs, computer runs a BI Server 24/7 anyways).
Mining with a single card at home is unlikely to turn a profit both with current market conditions and just practical conditions.
Here are the first things to consider should you attempt this:
keeping the card very cool; mining is a lot more stressful on the card than gaming. You will reduce its effective lifespan running this constantly as well without some immaculate cooling solution at home
the cost of your electricity
the cost of cooling the card (assume that for every watt of heat output your card creates, your home AC would spend another 2 Watts removing said heat).
Lastly, the coin choice itself.
Personally, since I like having a stake and my machine runs constantly regardless, I use NiceHash which hops algorithms based on market demand for coins and pays BTC. However, with the current market I hardly leave this on now and instead contribute to Folding @ Home since even my Vega64, which when I got it was making me about $90/mo after costs, currently only produces ~$1/day ($30/mo) before costs. The market is very soft currently.
If you want to run a single card you have a lot more overhead. Most mining rigs use a high card/system count to reduce the operating overhead of the system. Processors. motherboards, etc all draw power.
As for the coins themselves, I’ll let others chime in on options. My systems personally stick between Ethereum and Nicehash.
I second @hon1nbo’s opinion here. I have a few friends that were mining and have stopped because the economics have shifted to the negative/break even currently. None of them have called it quits totally, but their machines are off. I have one friend that is still mining and making money, but he has access to electricity that he isn’t paying for.
Thank you for your thoughts. Even if I break even (or slightly less), I’ll likely still participate for the learning involved. One point in my favor is the card’s power consumption is incremental since I run my machine as a surveillance server.
As much as it pains me to say it, run windows; the drivers get borked too often on the linux side for mining software.
I used HP SL250 blade chassis when I ran a mining and GPU compute hosting solutions; I actually donated my old personal blades to the makerspace.
We removed the shrouds on the Reference version nvidia cards so we could force air across the fins through the chassis properly. Most GPUs assume a flow from the intake of the onboard squirrel cage fan and out the back. Reference edition cards are great for this because the heatsink is oriented along the horizontal axis rather than the vertical.
NiceHas was run as-is with the full benchmarks done. Run as-is.
For Ethereum, we used NanoPool or similar with Ethermine, and setup a Telegraf+Grafana dashboard to calculate statistics and track progress. However, for a single unit just run the mining software directly as it won’t be worth the time investment.
IMHO, this isn’t worth getting into unless you just want a say in the network as a learning thing, it’s not going to be a profitable endeavour on that scale operating at a home.
When we had desktop / open air builds (which we stopped because they aren’t really that profitable for what you invest in it), we used the higher-end Celeron processors since they had enough PCIe bus lanes on the die, but didn’t draw much power compute wise.
When I input my API key from m-hash, CPU Miner - Coin Magi GUI tells me “Couldn’t update mining pool data”. How do I enter the correct API to allow for updates? Do I need to allow different settings?
Could someone please explain, in a couple of simple sentences, what exactly happens in the ‘mining’ process? What computations are the machines doing, and is it all set up and computed automatically? Thanks.
I started to buy $100 to gamble with in the BitCoin stock market, but the broker wants my Social and DOB…don’t really want to give that up. Is there a way to do this without having identity theft?
I have the RX580 and love it. It performs great for my VR setup and makes me a few bones a week when I’m not playing.
Currently, im mining Vertcoin because I like the community and want to support the network. I turn about 3-10 VTC a week depending on P2P pool’s luck.
It sounds like you just want to make a few dollars and hold some coin. Bitcoin would be the best to hold/sell as it’s the OG and most stable. If i were you, i’d look into Honeyminer. It mines the most profitable crypto for your computer and automatically converts it to BTC and sends to whatever address you want.
Monero has been pretty profitable for me as well, but you have to convert to btc anyway to sell.
Honeyminer mines Monero and Vertcoin, among others, in its coin selection.
Hit me up if you have any questions. I’ve run through the cryto mining rig setup a few times now.
Thanks @Corbimos. For the moment I’m stuck with CPU mining (currently 2 RPi2; 2 RPi3, 1 RPiZW, two old laptops and my Kaby Lake, netting about 95 - 125 kH/s pooled.
None of it is doing much for me, but none of my graphics cards are new enough. I’m playing with CoinMagi for a few weeks until I decide to pull the trigger on a ASIC miner or a RX580.
But you are correct. I’m really just playing around so I’m a little more knowledgeable before the next major bubble comes along. No need to make money now if just participating will net me a reward in long term holding…and even if it doesn’t it’s still fun to learn about I’ll definitely keep you in mind…thanks for reaching out. Feel free to private message me anything your willing to share.
I used to be in the banking industry and we had to have all that info. The SSN was for tax reporting and the DOB was for identity verification purposes when you called in. Did they also ask for your full legal name and address? that all sounds legit if its a reputable broker. Definitely do the research on the broker first.
The point of doing the math is so that there is a cost associated with mining. If there was no cost there would be no value to the end product (cryptocurrency)
It takes a lot of computing power which means that you have to spend money on computers and electricity, otherwise everyone would do it.
To clarify, it’s not to create a barrier to entry, but to ensure you can’t get something from nothing. This shows that users are actually active in the network to unlock the next round of coins, and the math processes the next round of transactions into the subsequent block.
