I have a rather large piece that needs repair. It is about 7ft X 5ft, made from 4in square steel, and weighs an estimated 1000lbs. Since we don’t have a forklift at DMS, I wouldn’t consider bringing it into the Metal Shop.
The frame needs to be straightened on a hydraulic press, welded back together, then reinforced to prevent this from recurring.
Attached is the CAD drawing with my finger pointing to the fracture location.
If any of you can recommend a Machine or Metal Shop in the area which can handle this job, please respond. Thanks!
