Ah, capacitors - just waiting for their chance to kill you.
In a previous career I was once tasked with replicating the layout for a circuit board we lost the prints for and were finally near exhaustion on the previous 5-year buy. It was a fairly simple affair with perhaps 2 dozen thru-hole components (relaty, transistors, coils, resistors, capacitors, etc). The sample I was given was fully assembled and had been pulled from stock. I set about getting the dimensions with a steel ruler - it had 0.01" graduations, but I would be doing well to be accurate to within 0.05".
As luck would have it, the last measurement I took was the pins for the biggest cap on the board - probably a 100V 500uF job - and was rather surprised when it arced, gouging out the second contact point on the ruler, rendering it somewhat useless as a precision instrument for that distance. Not wanting to further antagonize the capacitor and further plasma-cut my ruler, I fudged that measurement then went out into the shop and had one of the metal shop guys precision-shear the first inch off the ruler and put it back on the boss’s desk…
No idea how long that PCB had been sitting inventory - it’s equally likely to have been pulled from the test fixture as to have been the last one from the bottom of the bin.
But that was nothing compared to the time I grounded the lawnmower’s ignition system. Having the entire side of your body suddenly convulse involuntarily is quite exciting. Suspect I would have been sitting there with my fist grasping that wire with maximum force until the mower ran out of gas if it hadn’t stalled within a few seconds.
