Christmas ornaments is almost exactly the style I’m thinking. Option 1 is a plastic case for paper - If I lay them down flat, I need that 8.5x11 base; if I stand them, its only needs a lot more dividers. Option 2 is a case of 4x6 photo cases - less divider requirement, but the cases are more expensive, and I’m still debating the pros/cons of six in a case, because they came in sets of 18 or 20.
Masonite and plywood seem like a lot of cost and/or weight, which is why I grabbed a
Corrugated Plastic Sheet at Hobby Lobby to play around with. I haven’t used it before but it seems rigid enough (and light and cheap) to work. Would the laser cut it or melt it? Should the grain be horizontal or vertical, especially if it’s 3/4" tall?
I’m not sure 3D printing would work well for the larger size, I believe it would take a long time to print and the filament can be expensive. I’m also concerned its layered nature might not survive jostling from large numbers of heavy figures.
Thanks all for the commentary; I’m still trying to figure out all the details.
