What would be the best machine to use to bend something thin?
I want to bend some 0.020" thick aluminum, about 10" long. When it’s finished, it should have a 90o bend and be about 1/4" long on each leg. I think I can put it into the JSM guillotine cutter after bending and get the legs to the proper dimension, so that’s not much of an issue. I just want a good, straight bend parallel to at least one edge.
I have about a half-dozen to do.
I cosidered just screwing two pieces of board together as a clamping fixture (with the alum between them) and bending over that. I’m concerned that the “fold” will be wobbly if I do that.
