Been meaning to write something about this for a while, so here goes.
Most of the volunteer time I spend at DMS revolves around fixing tools, and over the past couple of years, I’ve fixed a lot of stuff. In the process of this, I’ve noticed a behavior pattern among people working on projects that goes something like this:
Maker working on a project, hits a point at which they either need a tool not located at DMS, or need something special, and project work stops for a bit. Maker shifts into “Solve the problem mode”.
After lots of thought, and perhaps discussions looking for a solution, sudden the big idea - “I can modify that tool to make it work” or “I can use this tool in a way I’ve been told not to use it, and it’ll solve my problem”. User shifts into “eureka mode”.
User modifies tool, usually destroying it, or breaking some part of it. Maker shifts into “I fixed it look how smart I am” mode.
The odd thing about this, is the users reaction if you interrupt his thinking (yeah his - have yet to see a girl do this). For example, I walk up to a table in the workshop, where two guys are exitedly discussing how to modify a screwdriver to give it a small hook and eyelet, to use threading wire under a car dash. I hear this, and interupt - “Hey, you can’t destroy DMS tools”. At this exact moment, you get “the look”.
I theorize, that “The Look” arises, as you force the Makers brain to shift too rapidly from “fix it/problem solving” mode, to “moral judgement” mode. This causes some form of cognitive dissonance, similar to epilepsy, where the persons corpus callusom becomes electrically overloaded, resulting in “The Look”, in which the users eyes grow wide, mouth gapes open, and the face shows a complete loss of coherent thought. After as little as 15 seconds, or as much as a minute, the first vocal response is typically “whut?”.
This will typically be followed by the argument “but i’m having X problem and this is the only thing I can think of to fix it, see, I’m just gonna do this and this”.
Yeah, that eureka idea is potent stuff.
At this point, the 60/40 rule applies.
60% of those confronted will recognize the wrongness of destroying a DMS tool, and 40% will not be able to release the eureka idea, and will simply wait until you get busy elsewhere, and then destroy the tool.
This seems to happen to most anyone - from noobie members, to Board members, and everything in between.
Anyway, thats my observation - sadly, I have no solution to offer,
