Bandsaw for stainless
Is there a bandsaw at DMS that I can use to cut some 16 ga. stainelss?
The large vertical one in the machine shop says aluminum only, if I read it right.
Training required?
Thank you!
The bandsaw in machine shop can be used to cut steel and stainless. You will need to make sure the speed is in low. High speed on the vertical bandsaw is for aluminum.
Thank you, sir!
