Note, I’m not trying to ignore this request, but…
Here
and here
and here
is one example of a member, currently on the BoD, rendering his opinion about using chemicals for etching and/or anodizing at DMS.
I could be wrong, but I have the impression the opinion this member posted represents all of the present BoD, collectively and individually, and, hence, the stance of DMS on this topic.
Check into alodining vs anodyzing. It might be easier and serve your purpose.
Fair enough. We all know David is exceptionally smart and well informed. I’m somewhat in agreement with your take on the BoD and DMS stance.
But, sulfuric acid is not a ferric chloride solution containing residual copper, and a solution used for anodization that has been tested to have a neutral pH following addition of sodium bicarbonate no longer contains sulfuric acid but sodium sulfate. Sodium sulfate is not harmful nor a disposal hazard so where does the hazardous disposal issue for light commercial facilities like DMS enter in to this?
Interesting when I first approached science with the idea of andonizing, I was told that all types
required chemicals that were a problem for us, I did more digging and found out niobium uses TSP and that
a non toxic etching solution for titanium had been developed Which we have–not made up yer since is has a
time to use after being mixed
That is what I based my comments on
You and any interested parties might check in again with the current Science committee chair and lab manager to see if the J&SM and Science committees can get these different anodization processes up and running. Each process and its involved chemicals and procedures should be reviewed on an individual basis but the current lab manager is eager to help out DMS members with chemical disposal.
Thank you Cairenn for keeping an eye out and voicing concern for issues related to member safety.
We are doing Niobium for several months
I want more interest in titanium before mixing up the etching chemical
Respectfully your wants are not what leads DMS. If there is an actual safety or compliance reason why it cannot be done then state it. Otherwise don’t be an impediment to someone who wants to use equipment in the way it was intended. I would expect anyone doing things like anodizing or niobioum would welcome ANY interest, not be an isolationist.
Huh ? We are not using any dangerous chemicals, we use TSP-detergent and water
I fought for several years to get the Niobium approved
I pointed out what I was told by the science committee several years ago
Science has used our equipment for other things
My reply is to this statement.
EDIT:
It appears I’ve misunderstood your comment. Please accept my apologies.
But aluminum is not titanium Different metals different chemicals
I think this is now in the hands of science since I am not a chemist It has been a long time
since my last chemistry class for me
If we can do aluminum and not violate code I would love it I like workig with it at times
Have you checked with Science? We have a power supply in Jewelry that Caireen has used to anodized niobium. This is beyond my knowledge base, but I know that Science is getting into plating metals and such and they have the big vent hood so you may be able to do some processes that require harsh chemicals. I know others are interested in this as well.
I’m going to be attempting anodizing aluminum in the next few weeks at home. Has anyone had experience with just using the RIT dye? I’m going to just anodizing black.
My larger part is about 15” long tube 2.25” in diameter, which will make doing it interesting. I haven’t decided yet how I’m going to approach the heating portions.
