I sent the SGC HF antenna tuner off for repair. It’s been a week or so. SGC said to expect a thirty day turnaround.
When it comes back I’ll schedule a SIG meeting and workday.
Andy Parcel has suggested adding a diplexer at both ends to separate HF from VHF+ frequencies. Then we can add a dual band or tri-band or whatever antenna on the roof and activate the second UHF connector on the yellow panel.
Question for the group - should we replace the currently-unused UHF connector with an N connector (to make it more clear which kinds of radios connect where), and perhaps put a discone on the roof that would permit activity on 2m, 220, 440, 900 and 1200? I have a discone in my attic and it seems to work reasonably well on all those bands. Probably not ideal for weak signal work on 2m and 440. We can get some N-to-UHF adapters or jumper cables for those wishing to use typical dual-band mobile radios on the antenna.
Might make satellite operation usable from DMS. Not sure. Anyway, suitable (up to 100w) discone antennas are not expensive - maybe $50 or so.
Thoughts?
Kevin
