I’m wanting to make or custom order a PCB that has many small holes in it.
The goal is to resemble PVC mesh like this. The only component on it would be 1515 leds like the ones in the picture.
The holes are 0.55mm in diameter in a hexagonal pattern with 0.75mm between them (as in, there is 0.75mm of plastic between the edges of neighboring holes)
The holes are just for appearance, they won’t need to be lined with copper.
Would the normal custom PCB companies accept a design like this? Could I make it in the makerspace?
I think it would only need 1 layer, so I wouldn’t need a very complex mill to make it.
Should I pick a specific material to make this out of? I’m not sure if that many holes would make a normal board really fragile. I would likely attach the finished board to laser cut or milled acrylic though, which may fix that.
