I have seen several people ask for a class to learn basic wood joints. I enjoy teaching classes that have a product to take home at the end so I worked on a small box today that I think we could get through everything important in a 3 hr class. I built the box below today and it is very simple but beautiful. Essentially it is a more beautiful version of a box a set of carving tools I own came in.
If anyone is interested in a quick run through I am going to work through the complete process tomorrow, Monday November 21st starting around 6:30pm. If I can get through the process quick enough I will set up a class in December sometime. This process will cover proper way to re-saw a board to create 1/4" wood for the sides and 1/8" wood for the top and bottom. I will show how to properly and safely use the jointer, planer, bandsaw, tablesaw and drum sander. The box is joined together with a simple miter joint and then splined with a contrasting wood for strength. I built a jig to cut the miters on today using the Sawstop tablesaw and was able to cut the miters for the complete box in 5 minutes after the jig was set up on the sled. The class would show how to use this jig as well as the spline jig and what blade to us for splines, the correct blade is very important if you want it to look nice.
