So my 2010 focus stopped blowing cold at the end of May and after some home diagnosis I found there’s freon in the system so a leak is very unlikely, but the compressor isn’t spinning up. A friend suggested I replace the a/c pressure switch just as a cheap check to see if it was bad, but I found out some Fords have a special valve there to close the system once you pull out the pressure switch and others don’t, and I don’t know if mine has it.
I want to just take it to a shop, but the ones around me seem a but shadier after new management, and one a friend recommended is a half hour from me. So I’d like a bit of advice as to how y’all would proceed.
Thanks in advance
