I was using the Domino XL today and it repeatedly stopped working. It did so first mid-cut so I thought I had plunged to fast. Switched it off and let it sit for a few seconds. Started it again made a couple more cuts, super slow feeds, and it cut out between cuts, not at all on contact with the work piece. Repeated the turn off/let it rest and back to work. When it stops it is as if it is loosing electrical power.
- This probably needs to be reported under the “Issues & Requests” category.
- Whether here or in the other category, it helps to tag the appropriate team that will likely take this up for further action, i.e. @Team_Woodshop.
- Request a Green Dot:
I’ll looks at it in a bit…
Thanks, HB
