Hi - I’m new to Makerspace and hoping someone can help me out. I am interested in signing up for the 3D printing class for ceramic use on September 9th, but it says I need to first take the 3D Printer Basics prerequisite. I can’t find anything by that name on the events schedule, but there is a Bambu 3D printer intro and signoff class today (sat, 9/6) at noon, which I thought might be the same thing, but that class also says you need to first take the 3D printer basics prerequisite, so I assume it is not the same. When is the prerequisite class offered? Thanks for your help!
The prerequisite, along with quite a few others, is located at learn.dallasmakerspace.org - you log in with your regular credentials, take the class (most of them you need to pass with the 100%), and then log out and into the calendar and you should have the permission applied. We have been having some issues with the online class system, so if after passing with 100% and logging out/ back into the calendar you’re still not able to sign up, just post a screenshot of your passing score here
I don’t seee a class called 3D printing class prerequisite - is it “Intro to 3D Fab: Polyprinter”??
Yep
0123456789
Hi I’m the instructor. That class was not supposed to require a prerequisite. I will fix it now!
