I recently picked up a '99 F150 which was owned by Paris, TX as a fleet vehicle up until very recently. Currently, an among other not working things, the A/C does not blow cold – as well as the blower occasionally and briefly cutting out. After speaking to Sam and watching a few YouTube videos including
- ChrisFix - How to Properly Recharge Your AC System
- ChrisFix - How to Recharge Your Car’s AC System (Fast and Easy)
I popped the hood and turned on the A/C and took a look at the compressor. I can see it cycle through the clutch engaging for about 2 seconds and then disengaging for about 6 seconds. After praying to the internet, the AI Gods bestowed upon me the knowledge that this could be caused by low pressure/refrigerant.
The truck takes 33oz of R-134a, which at O’Reilly is about $40 for three cans of Chemours R134a Refrigerant With Valve 12 Ounce - R134A-12V (just the refrigerant) vs around $120 for two cans of A/C Pro R134a Ultra Synthetic Refrigerant Kit 20 Ounce - ACP100V (includes a valve and gauge).
This being said, and as I don’t know the history of what’s been done to the A/C system in the past, I’d like to follow the steps in ChrisFix’s How to Properly Recharge Your AC System. This will clear out any air and moisture in the system – as well as save me about $80 which will pay for a good portion of the break pads and rotors that need replacing. Aside from the refrigerant itself, the video calls for:
- Manifold gauges
- Vacuum pump
- Nozzle to tap the refrigerant
- AC Vent thermometer
I’ll be in today around lunch to replace some broken studs on my drivers side front wheel and if I can find everything I’ll give it a shot and share how it goes.
