From my other thread:
Small Table Saw for cutting plastics. Yes - a dedicated saw. the woodshop (which will be on the other side of world) is so restrictive basically its a pain in the azz to try to cut plastics. BTW, the saws and blades as they are would cut plastics, but the rules are the rules due to filtering.
Router Table: basically for trimming the edges of the plastics. At minimum a trim router with a follower bit would be needed. I am willing to donate the router table for the committee.
Plastics Bender: I believe one exists and is under the Thunder laser. If it is in working order it will need table space.
Heat sources: basically a heat gun and torches for cleaning up the edges of acrylics.
Drill press: Available next door in the machine shop.
Storage Cabinet: needed to store adhesives, tools, project stock, etc.
===addition===
the vacuum former might be a good candidate for this space too.
