If I left a charger in the general computer area, did it go to a lost and found box or is it in charger heaven now?
Presuming that someone picked it up, it should be in Lost & Found, which is the shelf by Digital Media with the coats hanging on it (and obscuring the Lost & Found sign). If nobody picked it up, it’s probably Right Where You Left It. That’s the more likely scenario. I’d look, but I probably won’t be up at the Space until 5-ish.
also! there is a bin of laptop chargers that may or may not be consistently labelled as owned by dms that is meant for all the dms loaner laptops. (its in a bin under the DMS public use laptops locker in the common area) you might check in there as well. it is plausible someone helpfully placed it there hoping to return dms property to its correct location.
Thank you, it was in the lost and found
Thank you, it was in the lost and found!
