KISSlicer post-processing script failure
I was slicing a design today, and the post-processing step failed with Error 1. Has anyone seen this before?
This was the right-hand side PC up next to the exterior windows, as you are facing those PCs.
I believe that is actually an OK error, if it comes up with Error 1.
@axeonos or @themitch22 may have a better explination as to why KISSlicer gives us that error now
There should be no error. If the number is -1, then usually, it’s because Kisslicer was not started from a link that sets up the data path correctly. For example if the .ex is right-clicked to Add To Taskbar, it will probably give that error.
Normally, the installer makes a Start Menu entry that is correct, That can then be right-clicked to Add to Task Bar.
I will be there tomorrow and will check it out.
It also breaks when exporting files with really long names.
