I have two nice modular power supplies that I’ll donate to your cause. Use one and keep the other as a spare. They are each 12 VDC at 9 Amps. You will have to play around with the output connector as I do not have a mating connector. The connection diagram is on the label. I’ll leave them in the Electronics Lab above the computer with your name on them. I can drop them off sometime during the week.
The power supplies have been delivered to the Electronics Lab. Check the shelf above the computer.
its 12V and not 5V?
No youre right its 12V. I thought you could drive these directly off an arduino though?
Is just the data line at 5V?
Not sure the voltage on the data bus but LED strips usually come in 5, 12 or 24V
