Hey @Team_Woodshop anyone mentioned the delta bandsaw acting weird? A blade just snapped in two while cutting 5mm Baltic birch, tension seemed fine and didn’t see it hitting the guides. I was also barely putting pressure on the sheet, so I’m confused.
Edit: believe the incorrect blade was on it and I didn’t notice though I’m not sure if the jet and delta blades are different lengths. Blade has been replaced and seems to be cutting fine
