hey team,.
I just started woodworking this year and my first set of projects are resin /wood cheese boards. I need to trim sides of the completed boards etc. and I just wanted to double check. What machines CAN I NOT run my resin board through?
J
hey team,.
J
Per the current rules, you can use all tools, but, epoxy must be cured a minimum of 7 days before cutting/sanding with DMS tools.
Do your cheese boards have bark on them? The only tools you can cut wood with bark attached are the lathes and bandsaws.
See full rules here: File:Woodshop Rules 03 02 2022.pdf - Dallas Makerspace
Thanks ! No bark, and I try to leave the wood exposed over the epoxy. Appreciate the response .
