Hello,
I have taken the wood turning sharpening class to use the traditional turning tools, and I remember getting a handout for sharpening bowl and spindle gouges (that I since lost). What are the typical settings we are using for the community use bowl gouges? From what I have seen online, the vari-grind should be set to 23° degrees and the tool should protrude 2" from the jig. Then the raptor setup guides can be used to adjust the bevel angle.
I noticed that some of the bowl gouges don’t match the raptor guides with the settings above, so I want to make sure I am following the standard grind for the community tools. Let me know if our setup is different than what I wrote above.
As a side note, it would be great if all of the bowl gouges were clearly marked with their grind settings.
Thanks
