We received in a shipment of parts today and I’ve used the majority of them. The remainder are in the instructors cabinet.
Maintenance by lathe is as follows:
JUDY
Replace power switch assembly installed
Replace lead screw
Quill cleaned, channel dressed, sanded and re used.
ROSIE
New forward /reverse switch installed
Replace lead screw
Replace quill
Replace tail stock locking lever
Replace tool rest height adjust screw
ASTRO
Replace quill
Replace lead screw
ELROY
Replace quill
Replace lead screw
Replace quill locking lever
Replace tail stock lock lever
Tried to clean power switch but it is still faulty. It will not turn off reliably. Swapped with known good power switch and same condition occurs. Need a full power switch assembly.
Still showing an E6 error so it needs a spindle sensor and collar.
All tail stock castings cleaned and lubricated.
Dan- can you add this info to your spreadsheet?
All of the lathe beds need to be refinished and waxed. I’ll set up open hours on Saturday to solicit volunteers!
I’ll generate a list of needed parts and get those out by tomorrow.
