Will someone please tell me?
I have searched the post but did not find the answer so I wanted to know if DMS have a wood burner?
We do not have a wood burner unless you count the dumpster :wink: (small joke as it recently caught on fire, please don’t light it on fire again)
Most people use the laser, but if you want to get into pyrography we can look as a committee into getting a set. Usually though we need teachers before shelling out money on tools.
Okay I appreciate your answer thanks. Since you stated that most people use the laser than I will take the class and utilize that tool.
I believe that there is one in the CA room. I handled it when we did the reorganization of it. I didn’t realize we had one either.
I believe it is in the card file cabinet. I will double check tomorrow when I am in there.
Thank you for the information and definitely for checking I really hope there is one.
If the space does decide to buy one I have used a Burnmaster Eagle dual port for years and would highly recommend it. Maintains temp well and I have used it for hours at a time without issue. Lots of tips available and you can make your own also.
