Who here has a light box and may I borrow it?
I recently saw someone using a small light box in the jewelery area, but didn’t think to ask if I could borrow it at the time.
So I just want to photograph some small scale jewelry with it. It wouldn’t be much, just 30 minutes maybe.
Either way I would appreciate it and I could even give you a piece as a thank-you for letting me borrow it for a bit!
Ceramics has a light box. It’s sitting on top of the cabinets just across from Jewelry. Just be sure to put it back when you’re done. It might be bigger than you’re hoping for, though.
It depends by “Borrow” you can use this stuff at the space but not take it from the space without permission
I believe he was assuming that the light box he saw was personal property, not DMS property.
Oh. I’m looking and don’t see it on said shelf for the life of me…
Perhaps you mean the one in the media room that Ceramics uses frequently?
Yeah. It’d stay in the space the entire time.
Huh. I’ll have to go look. It was on top of one of the shorter Ceramics cabinets in the “Ceramics/Jewelry Flex Area” last time I was back there.
Back when I was glass chair I bought 6 light tablets the dept. I have no idea where they are now. Also, glass had a light table (not sure if it works) check with the current chair Vincent.
Right. Probably just because Ceramics uses it a lot. Perhaps not where it lives proper.
Right, except I’m looking for the light box. Not a table…
It’s where I’ve seen it for quite some time. However, that doesn’t mean someone else hasn’t moved it recently or has it in use now.
Well thank you for your experience
Update:
I found the ceramics light box on top of a drawer at the corner of Ceramics closest to the machine shop actually.
