Which table saw blade should I be using for cutting acrylic? I was at the space but couldn’t find one marked and didn’t want to grab the wrong blade. I’ll be back this evening. TIA!!!
You can use the Metal Shop bandsaw if you can’t find what you need
Machine Shops Bandsaw is currently down for repairs. Metal shop has a vertical bandsaw but is limited by size to cut larger objects & with no ability freehand.
I appreciate the info. My stock is a bit to large for a bandsaw. If I can’t find the blade, I will pick one up this evening.
I thin there is one in the (generally locked) tall storage cabinet near the miter saw station. I even think it is marked “plastics”. Cause I marked them all a while back…
Please remove and replace when you are done with it.
Laser table saw is usually my go to for acrylic
I usually use the laser cutter, but the kerf from the laser makes it hard to weld without a good bit of finishing, and then the parts aren’t exactly the size needed.
I will check for it this evening. Thank you!
