I am trying to find a couple of brass (or any shiny, pretty metal) pieces that i can use on the Metaza. Only problem is i need them yesterday (or before this weekend).
Pieces i need will only be 1" x 3", on shiny (not brushed) metal. They will be used as plaques on small trophies.
Does anyone know anywhere that i can pick something like this up?
Mark, I believe I have some brass plating you can use. I’m taking the airbrush class tonight and will be at the space around 7. You’re welcome to cut what you need, I think it’s a 12"x12" piece.
I have some small copper squares if you want to try that. Let me know, I’ll toss a couple in your bin. You can lightly roll press them for straightness and should wok harden them slightly. experiment for future copper work.
I have some copper sheet, not sure if it is still real shiny
it might need to be buffed first, I would need to check for
brass. I cant remember if ordered it or nickle silver in
Jan
Depending on the size you need, I’ve found the cheapest place to get a relatively thick piece is Home Depot/Lowes and get the solid brass door kick plates. An 8" x 34" plate is $59
