Does DMS have a wheel alignment kit? I’ve used portable ones in the past that measure toe and camber and I understand that some with a sliding platform can measure caster.
There should be a quicktrick kit somewhere…
It’s in a black bag on the rack next to the lift.
Personally I wouldn’t use it instead of a real alignment on my daily, but it’ll get you close. We use it on the racecar. It’s good for that, or a weekend vehicle/offroader/endless stream of PT Cruisers…
Mostly I want it as a check. If in indicates out of whack, I’ll spend the bucks on a pro if I can find one I trust to do more than put some wrench marks in the dirt.
The kit is in a black canvas bag, on the wire shelves, on the Laser side of Automotive. Please be sure to retun all the parts to the container when you are finished. Thank you.
