What still needs to be done to get the PCB mill back up and running
I have a need for some basic PCB milling. What is the current status and what is still needed to be done to get this machine back up?
@artg_dms
@Lampy
I think @Lampy and his son were the last to work on it. Last time I checked it still needed some kind of interface and control boards. Not sure what sftrwr is on the pc. or what the interface is. Was planning on contacting @william_petefish to find out what it had.
@Kentamanos I have seen you use this machine in the past. Do you remember what the controller was that it used?
@artg_dms @Lampy Do you’ll know if this needs a power supply as well?
Here’s the link to the machine: TransIP - Reserved domain
There’s a picture on there of the driver, but I couldn’t find details: TransIP - Reserved domain
Perhaps they sell replacements? Would probably be cheaper than Gecko drivers etc.
Thanks Ken.
Do we know what happened to the PC with the parallel port that was running this? As far as I know a PC with either MACH3 or EMC2 was never in the Electronics room with this machine before the thief stripped its parts.
It was in the dark corner.
Do you know if it is still in Electronics or was it taken by the thief?
I have sent the company, that Kent linked to above, a request for a quote on the replacement cost for the controller box. Will let you’ll know when/if I get a response.
It was definitely LinuxCNC (AKA EMC2).
Just further FWIW if you hopefully get to the point of needing a Gerber/Drill file based CAM:
For “CAM” operations, I typically used “pcb2gcode”, a command line tool that I think is available via apt-get on Ubuntu etc. Apparently the project lives here: GitHub - pcb2gcode/pcb2gcode: Command-line tool for isolation, routing and drilling of PCBs and there is “an experimental” GUI version of it here: GitHub - pcb2gcode/pcb2gcodeGUI: GUI for pcb2gcode
I don’t know if I ever actually ran any G-Code out of it (I think I just ran some stuff “high”), but this looked VERY nice: http://flatcam.org/. Its website makes it look old (a year since last “news”), but the project seems to be updated fairly regularly: Bitbucket
If you’re using Eagle, there’s something called pcb-gcode that I know @mrcity has run before (seems to be here: http://www.pcbgcode.org/).
Should still be in the corner along with new collections of other PCs.
