What Metal? First step is to figure out what kind of metal they are.
Details
I agree with Beth @dryad2b that they’re likely cast something-or-other - possibly “pot metal” (a cheap, high zinc alloy that melts just above 400 degrees). They all look different. IIWM, I’d show up to the Machine Shop committee meeting tomorrow (Saturday) with your parts in hand and ask the various attendees what metal they think they are. Machine shop has some files to test hardness and that will give some clues.
You may get some clues from doing a water-displacement test. Weigh them (in grams), immerse them in water and measure the displaced water, and then you can get the specific gravity. You’ll have to be precise to be able to distinguish them.
Grinding/Sanding
Comments about how-to
The castings may have a lot of porosity in them so grinding may actually make them worse.
Bronze files fairly easily (as metals go) because it’s mainly copper. If you plan to use a DMS grinder, please check what metals they allow. I know that no one allows aluminum on their grinder but I don’t know what other restrictions there are.
A Dremel is a good choice to smooth/polish them. You should check out RioGrande for [silicone polishing disks](https://www.riogrande.com/searchresults#q=silicone polishing wheels). You will probably want coarse, medium and fine. You can also get super fine but you probably don’t need that. You will need mandrels to put the disks on - can get at Rio or at CDC locally (for about $1.50 each if you go do CDC). However, you will be at it for a year or more if you’re trying to remove a deep engraving (OK, probably exaggerated but you get my point).
Bronze Castings
Bronze castings
If you’re lucky they are bronze, IMO. I’ve been machining a fair amount of cast bronze and mine has machined beautifully. However, I admit that I’m using a mill to do it. If you can find a good way to hold/secure them, you could use the Sherline mill to make them flat. However … if you suspect that it’s pot metal you’ll should check with the committee chair @TBJK for permission.
How to Engrave
Engraving comments
DMS does not have the type of laser required to engrave metal (fiber laser).
You could use CerMark (or equivalent) to laser mark
Hammer/stamps will depend on the material type. Someone in Jewelry can weigh in on this, but I haven’t had good success with a hammer stamp except on very very soft metals; i.e., copper or silver. Of course, I’m also a weakling …
Dunno what to suggest as a fill material, but IIWM I’d do the fill and then polish it smooth to remove any excess fill.
