I’ll respond to each of your posts here:
Bill,
Per “Tell us more about this project”, first have a look at this photo I just took:
That is a 2" diameter round aluminum tube with 0.25" wall thickness. DMS member Kevin wants an eight-foot long version of that and he is drilling all those holes by hand! Ouch. He wants to make many of these, so I am building a CNC 3-axis XYZ tool to drill those holes and sand it later on. So far I have two 8’ aluminum I-beams, 3" x 4", which will be the base, and all the other components except linear guides from Anaheim Automation which should be here in about 1.5 weeks.
Kevin will write the control software for this and I will build the hardware. I want the connector so Kevin can test his software using our existing rotary actuator which will behave exactly like my CNC tool, but it is much shorter.
talkers,
Thanks you for that info; now I don’t need to figure out those stepper motor control signals. As for the part number, I showed a photo of the connector to Jim at Tanner Electronics and he pointed me to what appears to be the right part. We’ll see tomorrow…
darrent,
You should wait for me to finish this CNC tool. I’ll own it but keep it at DMS, if allowed, for all members to use. The y-axis will start as rotary, exactly like our existing laser cutters can rotate a cup, then later I’ll add a linear option like our MultiCam and Shapeoko can do. Next I’ll allow a router or mill head to replace the drill so we will be more like our MultiCam or Shapeoko beauties. This new CNC tool will have an XYZ travel volume of 93" x 13.685" x 8" (height is 8") and is designed for soft metals and plastics.
Bruce
