The pad on the left, I’m trying to find it in Eagle but I can’t for the life of me figure out the technical name of it…
Thanks for your help!
mark
mark
There’s no one ‘official’ name for it.
https://www.pannam.com/blog/carbon-tactile-key/
http://www.abatek.com/designguide/04Electrical.html
These designs are totally dependent on the conductive contact geometry, so you may have to make your own.
I have seen those design guides. Was hoping there would be an Eagle cad library. Thanks for the tip though…now I have more to go on
I think that would be pretty easy to make into a footprint; the trick is to do a keep-out zone on the solder mask layer so that the copper isn’t covered (like a pad). ENIG finish would be best for these boards to prevent corrosion on those finger-like structures.
Is it possible to connect micro switches to these type of pcb contacts?
I would like to replace the silicon rubber keypad on a tv remote with individual push button switches.
I can’t figure out how to connect the switches, i tried solder but it would not stick.
Thanks
Yes/no.
You have to get down to clean copper to solder the micro switches in place.Use a good pencil eraser on the copper contacts to clean them and the solder shoudl stick.
It’s easier to buy a rubber keypad contact repair kit at Tanner Electronics and fix the remote that way.
If it has the grey/black material on the PCB instead of copper then you have to get through that crap and down to clean copper to solder.
Hi thanks for the eraser hint, I’ll try that.
I should have elaborated on why I want to replace the rubber keypad, I absolutely hate the tactile feel of those rubber keypads. I know that’s a little crazy
I like nice crisp push and click feel of switches.
