I know the horizontal bandsaw takes some significant “usage” aka abuse, but the blade is quite dull. I also experienced quite a bit of blade wander. I know the blade isn’t square to the vice, however this was well outside what I would consider acceptable. I did try to adjust the blade guides closer to the work piece, and the bolts that adjust the blade seemed to be tight.
If I need to open an issue/request, I can do that. Are the blades hidden away so that we don’t get blade changes weekly? If someone can point me to the location of the blades, I’ll swap it out.
