Water Purification System in Janitor Closet?
Anyone know who put it there? It’s not hooked up or anything. It’s also sitting on a poorly-made wall shelf that is slowly coming out of the wall.
Could it have something to do with this or has it been in there a while?
https://dallasmakerspace.org/wiki/Board_of_Directors_Meeting_20170319#Cleaning_Closet_Renovation
@bscharff it occurred to me later when I saw it that this was something Science wanted. @NightRanger should explain.
??? :confused: ???
Neither are true
This is an ultrapure water purification system that produces lab grade clean water - nobody should drink this or use it for an application unless they’re sure it’s exactly the water needed for the application.
Good to know.
Please make sure to inform us when things of this nature are installed so we know who to call when it breaks or leaks. Otherwise it just goes in the dumpster :frowning:
Please put a note near it so anyone walking up to it knows that. Thanks!! :slight_smile: :slight_smile:
A note at the minimum will be added after we’ve hooked up and tested the system :smiley:
Regardless of whether it is hooked up and tested, labeling is in order for anything kept outside of a committee area.
Right, good call. It’s done today
