Warrior DC IN Cable Wiring
Anybody got one of these laying around that can tell me where the 2 red wires are supposed to attach to the back of the jack?
I can make my assumptions, and will try that if no one has one to exploit for info, but I’d rather if someone could re-assure me…
Thank you!
Here’s mine with freshly self-removed black lead, but they both were attached to the same post. The reds were dangling when i got there.
And here’s a bit closer on the back.
I assume both red wires need soldered to the post just above the yellow wire in this picture, but I was hoping someone would know “fer sher”.
Thanks again!
https://goo.gl/photos/x4usSMjZNCtNrGcv5 - you helped me with black wire ( :D) so I took photos od mine red wires. Hope it helps you
Glad I could help you. Thank you for posting up your pictures!!
