I am working on a project that will require at least two gas control valves, and their associated control modules and wiring. These could come out of a gas water heater, or gas residential furnace. I do not need heat exchangers or other parts, so a leaking water heater or furnace with a bad heat exchanger would be great. I can come and get the parts out of the unit. Send me a PM or post here if you have something that might work. Thank you.
As I interpret it, you want from where the gas line hooks up to the water heater to where the gas line goes to the burner, but not burner assmbley, correct? Assume the pilot light assembly is also needed.
How soon, may be able to get you one.
That is correct, Photo. No huge rush, but in the next two weeks would be good.
I presume natural gas since propane is less common.
Either propane or natural gas. I am going to convert them to propane anyway. Do you have anything, TBJK?
