Does DMS have a vacuum pump/chamber that could be used for stabilizing wood? The pump is the main thing that I am wondering about. I can make a chamber for pretty cheap.
Has anyone stabilized wood before? I haven’t, but it doesn’t seem too hard and would love some tips/tricks for DIY chamber/pump as well. Can a hand pump work? can I use something like a mason jar that I have around my house?
Thanks! I will check it out next time I’m at the space. Stabilizing wood seems pretty interesting to me and I want to learn how to do it but don’t have a lot of extra money to invest right now.
I’m wondering about the pressure pots and or vacuum chambers alluded to in this thread re: CA:
I don’t know how kindly they’d take to using it for this purpose, if we still have it/them, but it seems like other folks use similar equipment happily…
As @uglyknees has said, there should not be any problem using the vacuum pot in CA - as long as it doesn’t damage the pot. E.g. you have a smaller pot inside holding the wood and the goop it is sitting in, don’t pour the goop directly into the pot so it is not contaminated. Best take this stuff out into the shop to do it so any oders or vapors aren’t concentrated in the CA room. This is no different than when people make molds.
Thanks! I was planning on putting it in a small metal pot inside of the vacuum pot. I plan on using Cactus Juice, which I think has low fumes, if any, but will still take it out of CA.
If you think there will be any sort of volatiles coming off, you should seriously consider a cold trap of some sort inline prior to the pump. nothing ruins a pump faster than gummy volatiles that vaporize under low pressure and then congeal in the pump when pressure is equalized.
