Hey everyone,
I own a Rocket Press manufactured by Firesmith Tooling, here is a picture of the press:
This is an electronically controlled 14.4 ton hydraulic press and I would like to change how it displays pressure. Currently I’m relying on an analog pressure gauge that shows 0-3000 psi of the cylinder. I would like to change this to a digital gauge that shows the pressure applied in my rocket tooling. my tooling uses rammers that are .75 inch, 1 inch and 2 inch diameter and the hydrolic is a 3.5 inch diameter cylinder. So I’m often having to do non-trivial conversions of pressure to make sure I’m not over driving my tooling.
What I hope to have in the end is a hydraulic pressure sensor hooked into an arduino with a display. The arduino would have options for outputting the pressure for the different tooling im using with the pressure already converted for the tooling.
What do you all think, is this a minor project or a major one? what do you think I should set a side for budget? and suggestions on sensors that will work that cover 0 to 3000 psi?
Thanks,
Nick
