Tormach temporarily down[9-16-24]
Hey guys as the title says, the Tormach is temporarily out of service. We are working on shortening the table. I will update this thread when it is back in service.
Progress forward
The monitor has been re-mounted. The keyboard mount needs to be modified to fit or replaced with a larger base size. We should have another keyboard mount but I’m not sure of the mount size. The coolant base/reservoir also needs to be mounted.
I will build the keyboard mount on Saturday morning .
Kevin
The new height is fabulous! Even I can use it. Thanks.
It looks like it’s basically ready but missing the coolant tank. Any idea where is it and what it needs to be back in service?
It is on the floor by the haas vf2. I was waiting to build a drip
Pan, but it could go on any time .
Let me know what needs to be bent up
I was just thinking of a drip pan that goes under the lathe to catch the coolant that leaks . It just needs to be the size of the lathe footprint and have a hole where the drain/return goes . I will 3d print a tpu grommet for the gap around the drain/return . The leaking is minimal so the lip does. It need to be too high .
