Have you ever heard of Router Templates?
They are used to add shapes to wooden items. Shapes like handles on charcuterie boards, outlines of cartoon characters, and inlays. This class takes you from zero to awesome in a single night. You even take home your very own Bunny that you will make using this method. Save $20-$30 each time you create a new design vs purchasing templates from a vendor. Who knows, maybe selling router laser templates can be your new side gig.
Friday Class https://calendar.dallasmakerspace.org/events/view/22607
Limited to 5 members
We are waiting for the class to post on the calendar.
If you aren’t too busy and desire to learn a super cool skill that you will for the rest of your woodworking adventure, grab your seat now. There is only one slot left for Monday night, but a few slots left on Tuesday and Thursday evenings.
This is a skill packed class. You are going to learn many things and gain knowledge and confidence that could otherwise take years.
- The only prerequisite needed is Woodshop Safety & Orientation
Some of the awesome skills you will gain:
Image Processing Skills
- How to pick the correct Internet image.
- You will learn how to convert (auto-trace) an Internet image to a vector file.
- Scale the image in Lightburn the size you need for your project.
Laser Cutter Skills - The Laser section is a group demonstration - Laser certification isn’t required
- The process of connecting the Laser to the design computer.
- Apply laser cutting speed and power to the image.
- Insert the Acrylic into the Laser machine and focus the lens.
- How to frame the job.
- How to select where you want to cut.
- Starting the Laser job.
- How to pay for your time (including a nifty short-cut to track your time).
Bandsaw Skills
- How to properly transfer the template to your wooden blank.
- The most effective process to rough-out your blank.
Router Table Skills
- How to properly attach the template to your work piece.
- How to install and set router bit height.
- The proper way to remove the excess material.
- How to remove your template from your item without damaging it.
Checkout these examples you can will be able to make after taking the class.
Bandsaw Skills
Router Table Skills
Acrylic Router Templates By Crafted Elements - Easiest Way To Shape Charcuterie Boards And Handles
The Beginners Guide To Router Templates For Epoxy & Wood Projects
As always, I look forward to sharing my knowledge with you and help accelerate your journey to mastering woodworking.
