I need to cut a big piece that uses that whole cutting area. I noticed the the main door/lid is smaller that the actual cutting area, I did some researching and I found the only way to use the whole area is to open the panel on the front. To open the front panel you need a key does anyone know where the key is.
That’s the passthrough and requires dismantling the back panel. Currently we arent set up to use the passthrough.
The bed has a ~3" margin on each side for the “actual” cutting area so you aren’t going to be able to use as much space as you think.
Ok thank you, it says on the wiki that the cutting area is 5.5ft by 3ft does that in include the gap.
I’d have to look on the website, I’m not sure which one is which
