I seem to be emptying the Felder more than my share of generated sawdust. Perhaps I’m generating a ton of chips or I am overly conscientious about checking the Felder or others just don’t check it or I am unlucky to be in the shop when it is close to full.
Which got me thinking several questions:
Question 1: What am I contributing in terms of chips? I recently planed 1/8 off of about 20 square feet of wood which is about .21 cubic feet of solid wood. Kind of a typical jointing/planing session for me.
Question 2: How much expansion is there when you plane wood? A quick search of the internet found expansion factors for planing wood between 3 and 4. Ie take the solid wood planed off and multiply by 3 or 4 to get the volume of loosely compacted wood chips. Since I generally don’t trust the internet. I calculated my own expansion factor using my planer and dust collector at home – long story short, I got an expansion factor of 6 using pine.
So .21cubic feet of solid wood planed off * 3 = .63 cubic feet of chips at the low end to .21*6 = 1.26 cubic feet at the high.
Question 3: how much does the Felder hold? Per the Felder manual – the storage bins hold 500 litres of chips (2x250 each) or about 17.6 cubic feet. So I filled up somewhere between 3.5% to 7% of the Felder.
So I’m not generating a ton of chips.
Recently someone jointed/planed about 100 board feet of cedar – don’t know how much they planed/off but it was probably taking 4/4 down to .75 so maybe 3/16” or ¼” (a guess) so that should have generated 9.4 to 12.5 cubic feet of chips. Even that wouldn’t fill the felder. Don’t know what was already in the bins or of the expansion factor is valid. But… It takes a lot of wood to fill up the Felder bins (17.5 cubic feet is planing/jointing 200 square feet of wood 3/16” of an inch assuming an expansion factor of 6)
It might be useful to have a chart of generated chip volume given square footage and depth planed/jointed. But we should verify the expansion factor.
Next step: Calculate the expansion factor for our planer/jointer on hard and soft woods and generate a chart – I’ll run this test next time I have a lot to joint/plane because it interests me. Has any one calculated an expansion factor for our jointer/planer and Felder system?
But knowing what you generate is interesting to know but it doesn’t tell you if the Felder is full. Something even more useful might be to install windows on the bin – it looks like newer Felders come with windows! [Maybe it was option at the time we purchased the Felder that costs 2.7 gazillion extra dollars and we decided to save the $$]. Then it would be easy to see of the Felder is full or not.
Anyone want to do minor surgery (but wait until Ian says it is OK)? One question – would adding our own windows somehow void the existing warrantee (if any)?
Bottom line- I’m not generating a ton of chips – I’m probably overly conscientious and/or others don’t check as often as they should. Charts to estimate chip volume are interesting but don’t solve the “is the felder full problem” like a window in the bin would.
@Ian – Thoughts? Has this come up before?
