That hose in the sink? Shouldn’t have been on the floor. And the valve most definitely shouldn’t have been left open. Because when water valves get left open or stepped on or the like, the closet gets slowly flooded.
Watch what you’re doing. Look after the space. Don’t flood us, please and thank you.
Thanks for handling the situation @LAndras
This is the second time this has happened. I am going to assume it’s an accident, the valve on the end of the hose turns easy and there isn’t a hanger for the hose.
Can you or @maxk68 print one of these for us today? https://www.thingiverse.com/thing:2111859
Let’s install it so the hose hangs above the sink, that way if it falls off it lands in the sink and we don’t get a spill.
We could also pickup a basic water alarm and place it on the floor with next to a note (laminated) explaining the issue. So it’ll be obvious to anyone nearby if it happens again.
My 15-seconds-on-google understanding seems to think she’s right. The risk presented is that dirty water could be drawn back into a clean water system when the clean water system is being drained, and contaminate the system.
A typical faucet doesn’t have this problem, because there’s always an air gap between the maximum level of the waste water (top of the sink or overflow drain) and the level of the clean water (at the head of the faucet).
However, since this hose can be left anywhere, it could be left in a sink full of waste water. If the valve were open/leaking, the hose in a container of waste water (or more likely sewage that’s actively backing up into the sink), and the clean system being drained, it would be possible for this hose to draw waste water back into the clean water system. Unless of course preventative measures, like a backflow preventer, are in place.
We might already have a backflow preventer in place, esp since I think this was installed by a licensed plumber and inspected already?
Thanks for the info, I am not sure if that part was installed by the plumber or if it was there and they just didn’t touch it.
I’ll pick up some of the hose backflow preventers like the first link mentioned so we can be safe.
Thanks to everyone for everything, from stopping the spill, and handling the clean up to putting solutions in place the both prevent the situation and improve our safety. It turns out y’all are excellent!
Yep, everything @michaelb said. A hose bibb vacuum breaker is needed to protect against backsiphonage… I just couldn’t tell from the picture whether or not there’s one installed.
