The VacuFormer is now operational
Thanks to funding from John Haskins (Blacksmithing Committee @jhaskins) new wiring and connections have been procured and installed on the VacuFormer. A big thanks to Lance Preston for getting the specialty parts needed and fixing wiring issues.
The VacuFormer can now be plugged into the 3 phase 30A power socket on the Pillar behind the parts washer. It also needs 120VAC for the air/hydraulic system and shop vac. It also needs shop air connected. Some time in the future, the 120VAC will be built into the machine so a separate connection will not be needed.
Thanks for working on that!
Can someone work on writing up and laminating a basic instruction sheet to attach to it? Mentioning things like don’t leave it plugged in (leaving heating element going unsupervised would be bad)
To be truly fully functional it still needs a more powerful vacuum system. Every pull during the last class session lacked definition because the suction of a shop vac cannot pull hard enough or quickly enough when the plastic is in a pliable state.
That being said, I’d kick in funds to procure one. It will be a valuable tool when complete.
Would hooking up a $50 leaf blower/vacuum from harbor freight be better than a shopvac with a clogged filter?
http://www.harborfreight.com/3-in-1-electric-blower-vacuum-mulcher-62337.html
If you are trying to use a shop vac for the former, the filter should be removed.
If you can get the system well sealed, the pump and accumulator it came with is actually a really good soluton.
Yeah, it is functional, but needs tweaks.
I have that exact leaf blower, I use it to pick up grass clippings and leaves from my lawn. It’s even less powerful than a shop vac.
I think the definition would be increased with a better vacuum bed also -
smaller holes would help. We can make one on the multicam.
BTW, if anyone is up at the space late, I can help you learn the machine.
Just bring a piece of appropriate sheet plastic cut down into 36"x36".
I have an electric craftsman leaf blower / mulcher thing that we could try out, can anyone suggest a way to measure amount of vacuum it can generate? (it’s designed for cfm, possibly wouldn’t pull much of a vacuum) Would a clear tube filled with water instead of mercury work? Somehow get it connected to ac manifold gauges?
Yes it will work; however, if I remember correctly the standard 30 inches of mercury (standard atmo pressure) is equivalent to 30+ FEET of water
Wasn’t there a huge vacuum pump/tank next to the vacuum former at one point? I think the ideal solution would be a vacuum accumulator/tank that would be “charged” using a pump. Then you’d do the pulls off of the tank, giving an instant and very strong vacuum.
A simple water column could be made unless someone has some mercury which would allow it to be made a lot smaller. :grinning: Does anyone have one of the old vacuum manifold gauges used for tuning car/ carburetors? Some HVAC gauges can show vacuum (suction) although the scale is usually very small compared to the PSI side.
I can get my hands on a mercury manometer, we have a coffee can full of them. Also I do have a micron gauge we could use just for testing. On a side note just a standard low pressure gauge for manifold set would get a ballpark as well.
Also forgot to mention that a vacuum accumulator may be the best option. I think I have some 6" pipe at home we can use for one.
I have a large (80 gal?) vertical (small footprint) tank I had originally intended as an accumulator tank for an old vacuum forming project. It will require fittings/adapters, but I would like to donate this to DMS.
I also have a 15amp industrial vacuum pump I would like to donate.
Assuming these would be useful to the DMS, who should I arrange this with?
or you could get better definition (for stuff like rc car shells) by using plastic that isnt 1/8 - 1/16 thick. you guys are putting the effort in the wrong parts of the system
Coordinate with Science committee.
It seems you can coordinate with @jhaskins as the vacuformer is not currently sponsored by any community at DMS.
…X…
Edit: corrected the suggestion presented.
Ummm, why?
Science doesn’t own the Vacuformer, and they didn’t pay for the recent electrical upgrades to it. Blacksmithing (John Haskins @jhaskins) paid for it and taught the last class for it.
You are right @StanSimmons , he should coordinate with @jhaskins . I re-read that thread of “Do we need a Plastics committee?” where I miss-read “The Science Committee” Sponsoring the Vacuformer. Currently that piece of equipment not officially under any specific committee… Still.
^^…THERE is the WHY… ^^
…X…
