So, as I have posted before, I’ve built a 1,000 yard rifle, and have been actively working on load development for it. to shoot at 1,000+, you need a rifle/load combo with extremely tight intrinsic accuracy.
Using Blank Hills match ammo, I am consistently able to shoot .35" groups with this gun all day long. But after 2 separate ladder tests, my handloads could not produce better than .65" groups. This forced me into examining my precision loading routine and tools. Handloads, properly done, should always beat factory loads.
After a really critical look at my routine and tools, I could find nothing out of order. Case prep looked spot on (turned necks etc). I was weighing every charge, Seating depth duplicated the BH ammo. I could see a node at the 43.0g-43.1g mark, but my chronograph was listing extreme spreads and standard deviation values that were just too high to produce a really small group.
Hmm.
I settled on the charge as the culprit, since all other variables seemed excluded. After a great deal of reading, I learned that most electronic powder scales use a strain gauge as the measuring element, and that strain gauges were accurate to only 1/10 of a grain (4-8 kernels of Varget, in this case). LR competitors reported that this wasn’t accurate enough - you needed to weight to individual kernels of powder. Balance scales generally are accurate to less, as a result of wide lines and reading errors, along with unclean knife-edges. They also take a long time to weigh with.
I’ve been using a Hornady Lock-n-Load powder dispenser. Accurate to .1g, but internet anecdotes report it to be closer to .2g with stick powder.
So, I determined that I needed a scale accurate to within .001G ( 0.0154 grain). Jewelers scales are often this accurate. So I found a Gempro 2 -300 scale on sale for $165 (http://myweigh.com/product/gempro-2-300/), and ordered it. It arrived today. So next step, another mini ladder test, focused around the node at 43.0 grains of Varget. I’ll post results later for the (admittedly few) people interested in this.
So I guess you can take away from this that not all measurement systems produce precise and accurate results. LR ammo requires a lot from the reloader. I guess I’ll save the LNL for hunting ammo and pistol stuff. Mostly, for loading Tapper’s Premium 6.8SPC II HD (Hog Disassembler) rounds.
