I went by and messed with them today. The small one did not power up properly. I had to put in a 1A fuse and move the fuse holder cap from the DC fuse holder. Anyway, the standby Indicator lit but when I switched the power to Line nothing came on other than the reticle/grid. The LCD frequency indicator didn’t light.
I did not try running it on 12Vdc to determine whether or not the internal ac supply was good.
It needs a fuse cap anyway.
I then turned my attention to the Tek. It powered up just fine and went through the paces. It appears that many of the push button and rotary switches are very dirty. It may be that a thorough spraying with tuner cleaner might make it much happier. And I’m sure a basic cal would be indicated. But other than that it seemed to work.
Neither one - as well as I can determine - has a tracking generator. Which is not the end of life as we know it but makes it somewhat less useful from a duplexer and filter tuning/test perspective. Good enough to prove that your recent Baofeng purchase is/is not compliant with FCC part 90
So, if we want to save our pennies for a new bit of kit, do we want a VNA or a service monitor or what?
Another thing - Andy and I installed a new 3U wall rack and remounted the access panel. However, the wall anchors on the left didn’t hold. Probably need to be replaced with a toggle bolt or something. So it droops on the left. But the Alinco power supply is on a shelf above the panel. I still need to dress the wires and so forth underneath but I think it looks better overall.
Anyone with some spare minutes and a wall anchor is welcome to fix the left mount and dress in the wires!
What became of the 900MHz repeater project? Did anyone file for a repeater frequency pair? And what is this 60’ tower of which you speak?
73,
Kevin Grantham
N5KRG
214-763-1279
